Deletes an MLD SSM Mapping entry on a VR.
| v6groupnetmask | You must provide group address with the mask length. Instead of configuring separate entries for a continuous range of IP addresses, this optimizes a range of group IP addresses to be configured as a single entry. |
| v6sourceip | Specifies the source IP address for which the SSM should apply. |
| src_domain_name | Provides the option to use DNS to obtain IP addresses dynamically by specifying the domain name. |
| all | Specifies that all the mapping entries associated with v6groupnetmask are deleted. |
| vr vr_name | Specifies the virtual router name. |
N/A.
When an MLDv1 report is received for this group or group range, the list of sources configured using this command is used as part of source-specific information to PIM.
The following error message displays when specified entry is not found:
ERROR: SSM Mapping entry (ff30::1/128, 2001:0DB8:1::10) not found on VR-Default
The following example deletes a MLD-SSM mapping entry:
configure mld ssm-map delete ff06::/64 2001::1
This command was first available in ExtremeXOS 15.5.
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
